How do you rip Blu-ray movies off from the original discs onto your Mac HDD, for watching with media player software, or for any later burning or converting task? The answer could be as easy as you may think, with a Mac Blu-ray copy software, such as DVDFab Blu-ray Copy for Mac, you can do that job with great ease.
Check the step-by-step guide now:
Rip Blu-ray off from Disc to Mac HDD> Step 1: Download and install the latest DVDFab 9 for Mac onto your computer;
Rip Blu-ray off from Disc to Mac HDD > Step 2: Launch DVDFab 9 for Mac, choose Copy option in Option Bar, and then insert the Blu-ray disc into the external Blu-ray drive;
Rip Blu-ray off from Disc to Mac HDD > Step 3: Select Full Disc or Main Movie mode on Mode Panel, click the disc icon at the “Save to” section to select a path for the resulting movie, and then press the “Start” button to let go the burning.
Software you need: The latest build of DVDFab 9 for Mac
Product you need order: Blu-ray Copy for Mac
For more information, please go to: www.dvdfab.cn/blu-ray-copy-for-mac.htm
